11-12-2013, 08:28 PM
Barbeque hung off siding issues?
We have the supplied barbeque that came with our 2014 5th wheel that attaches to the rail on the siding. I have concerns about the heat that is subjected to the trailer siding. Has anyone experienced any distortion or other issues from this set up. We are using it on a separate table now but would like to use it on this rail setup.
11-12-2013, 08:33 PM
This has been brought up before, and I've yet to hear of anyone who has had any problems with it hanging on the side.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
11-12-2013, 09:02 PM
Have been using one for going on 6 yrs with no problem. 4+ yrs on our tt and 1+ on our 5er. Don't even get grease on the trailer. Works great.
11-12-2013, 10:13 PM
It has worked great for us for over 3 years.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
11-13-2013, 04:25 AM
Same here. No issues except if there is a open window nearby and you get the wind blowing in the right direction you might get some smoke in the interior. Besides that, no issues heard with the trailer siding melting or fading because of the Barbeque.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
11-13-2013, 08:03 AM
Been using my hang on rvq since 2005.
Turbs
11-13-2013, 08:27 AM
Clearly cooks greak food
Seen on left rear... I can smell the baby backs cooking from here.
11-13-2013, 12:19 PM
Same here. No problems with grease or heat on side of camper. If in doubt, place your hand on the camper behind the grill during cooking.
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
11-14-2013, 09:01 AM
I have had the barbeque on the side and heated it up while checking the back against the siding. It seemed to me that it was very warm, I could still touch it with my hands but not for long. I even placed a piece of cardboard there to try and reduce the heat on to the siding but concerned that would start on fire. My next thought is to wrap a piece of card board with tin foil and try that.
Has the siding been the same material over the years?
If none of you have had an issue then maybe I'm over reacting.....|I'm sure this would be covered under warranty if anything should happen.....NOT!
Thanks for all the input.
11-14-2013, 11:47 PM
Don't put anything between the grill and the RV wall, especially something flammable like cardboard. The gap between the grill and the RV should act as a chimney. This will keep air moving and move the heat away from the area.
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
11-15-2013, 03:53 AM
Just a member
Echo the comments thus far - we've put ours through the ringer for three seasons with no issues. Lots of burgers, steaks etc and although the side of the TT gets a little warmish, it's not so much so as to get raise some hairs. There's a warning too related to the use of the RVQs to not fire them up under the awning. Umm... we done that too (rain) on a number of occasions - no worries. The caveat is that you stand by your cooking apparatus and closely monitor the operation during the production of succulence.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
11-15-2013, 07:57 AM
I had one and it didn't cause any problems other than, as somebody already said, the smoke getting into the trailer via an open window. I had a rack that the BBQ hung off of and it came with the BBQ. If it's the same style as the one I had then you could take it( the rack) off the wall and set it up on a table next to the trailer. Mine was under the awning and there was never a problem with that either but be vigilant. Just like the one in the above post by Kandl.
11-15-2013, 08:03 AM
Good point I forgot to mention bracket can be turned so grill can be used on a table top as well as hung on the side of camper.
11-15-2013, 08:07 AM
Op is this yours?
If so turn the hanginging bracket on its back"where it would mount on camper"
Then set your grill on the now vertical pipes via the second "t" mount on grill.
11-15-2013, 04:04 PM
without knowing which grill you're talking about, it's not easy to say.
most FR products come with the Sidekick grill, NOT the RVQ. many call theirs an RVQ but FR hasn't supplied those since before 2005.
and are you using the supplied bracket correctly?
we've been using ours for the past 7 years and NEVER had any issues.
is it the best BBQ grill, NO! but it works quite well for dogs, chicken, burgers and most smaller grill items.
the side of our trailer never gets as hot as it does sitting in the summer sun for hours!
11-15-2013, 10:37 PM
Just a member
Concur but FR adds to the confusion by continuing to refer to the outdooe gas grill arrangement as "RVQUE" in their brochures. Many simply abbreviate to RVQ. From the 2011 Rockwood brochure - same for 12 and 13
11-15-2013, 10:50 PM
Yep
11-16-2013, 02:11 PM
Works great for fresh pizza too! Just put on low, slide your fresh crust on the grate for about 3 minutes, pull it off, flip it over, put your toppings on and return to the grill for about 10 minutes until cheese is bubbly and brown. Yum! Of course, works bettrr with a Round Barn Woodcrafts pizza peel. Insert shameless plug here. LOL
2012 Rockwood 8293RKSS
12-02-2013, 07:29 PM
So then here is a question... My new RV doesn't have the rail on the side but does have a propane connection. Should I let the dealer install a rail for me, do it myself, or not do it at all since it didn't come with it. I have an extra sidekick that I bought a few months back.
Just glad to get away
12-02-2013, 07:38 PM
Regardless of who does it, MAKE SURE they put a backer board inside to screw/bolt thru. Otherwise it will be coming loose or coming off. The factory mounted rail on our 08Flagstaff 831RLSS came loose the 1st time we used it. Dealer put longer, bigger stainless bolts/nuts thru a backer board and it never came loose again. Our 12Flagstaff 8528RKWS has longer screws into a backer board.
