Originally Posted by bubbles
First off the Wally has no direct coax output and if the Wally RF output runs through a modulator to convert to coax for other TV's there is no issue with splitters. Splitters in the output coax side of a sat receiver is not an issue. There is an issue when splitters are between the sat antenna (dish) and sat receiver. The OP is most likely using the HDMI output from the Wally. If a second antenna coax was installed and routed to a second Wally it most likely was direct. The OP should explain the installation that was done. Don't think coax distance is the issue though.
The Wally has a coax INPUT. I have the Wally HDMI output going into an HDMI selectable splitter allowing changing from AppleTV or Wally. There’s another nonselectable but powered splitter that sends that signal to both the living room and outdoor televisions.
All the pictures are top quality 1080p with no interference at all.
