Both AC Not Working
We have a 2014 Forest River Georgetown 360XL. The Dometic AC units have always worked - both the unit above the bedroom and the unit above the living room. (There have been times where a breaker popped or a fuse blew, but I've learned where they are and how to fix them.)
This time NEITHER of the AC units is working. The thermostats look okay. I push the button to set it for "Cool" - the little green light says it should start cooling, but neither the fan nor the compressor comes on.
I have tried it using the generator (with and without the inverter on) and with and without the key in the ignition and with and without the engine on. Then I plugged the RV into 50 amp shore power and tried again. Still Nothing.
I've examined all the breakers in the bedroom, and all the fuses and breakers by the House batteries (under the steps), and the breakers on the Onan 5500 generator. All of them look good.
Does anyone have any ideas?
