Originally Posted by Ed Cummings
To make matters worst, the antenna is not working. I was at least able to get a few channels that way.
Are you camping somewhere you can receive over the air stations?
If you've scanned for channels, made certain your signal booster is on for OTA, and tried moving the antenna (if that's possible), then I'd check the tv cables to make certain nothing has worked it's way loose. If none of that works, then I'm as stumped as you.
