Logic does not always apply, especially when RV manufacturers label things.
The CABLE connector on the outside of the RV NORMALLY goes to the splitter/amplifier and is designed for cable TV input that does not require a digital box, it is for cable systems that connect directly to the TV so you scan for the channels.
The SAT/AUX port should be a direct COAX from the storage bay to the panel behind the TV it is designed to be used with a receiver box system such as you ran into or for the satellite receiver to connect through to the dish.
(Previous) Coachmen Mirada Select 37RB
(Previous) Coachmen Freedom Express 246RKS
(Current)2022 Grand Design Reflection150 226RK
2022 F150 Powerboost Hybrid.
