Are you sure you did the same scan both times?
You mentioned doing a 'cable' scan first.
That won't work.
Different TV's are different but you need to find and do an 'antenna' scan or sometimes called 'off air.'
The way you are connecting it with the cable connection is just basically adding a longer coax to the mix. That shouldn't have a thing to do with not getting UHF channels.
