Old 06-10-2021, 11:56 AM   #1
Can I hook both roof a/c to one thermostat?
I have 2 roof a/c. Each one is hooked to its own thermostat and the thermostats sit side by side. I would like to get a single microair thermostat and hook both a/c to it. Figure it should be easy to y the correct connectors so the a/c units come on at the same time. Am I nuts? Here are the current thermostats.
2015 Chevy 2500HD 6.0 4x4 CC SB
2021 Salem Heritage Glen 290RL > GenY
1600W solar > 8400Wh LiFePO4 > Victron MultiPlus II > Cerbo GX
corn18 is offline   Reply With Quote
Old 06-11-2021, 11:22 AM   #2
Technically yes since you are just triggering relays with a t-stat, but the real question is why? You will be using power than needed when one unit will do the job. Possible short cycling the units because of over cooling (like having a home unit that is oversized), etc
2021 Flagstaff 21DS
2015 Silverado 2500HD (overkill but convenient)
Renogy bits: 3000W Inverter/Charger, 400Ah LiFePo4, 40A DC-to-DC
Rich Solar bits: 400W of panels, 40A MPPT
Misc bits: LevelMatePro+, SolidRemote based wireless controlled LED storage lighting
jbflag21ds is offline   Reply With Quote
Old 06-11-2021, 12:55 PM   #3
I decided not to do it. I can't run one a/c off the generator if I hook both up to the same thermostat. I just moved the one thermostat for the bedroom into the bedroom. Baffles me why they had them both in the kitchen.
Old 06-11-2021, 01:07 PM   #4
Both in the same room is strange. Glad you were able to move the one to make it more useful.
2021 Flagstaff 21DS
Old 06-13-2021, 01:00 PM   #5
U.S.ArmyVeteran's Avatar
At Forest River that is known as a "upgraded feature"
U.S.ArmyVeteran is offline   Reply With Quote
Old 06-13-2021, 03:57 PM   #6
It would have taken quite a bit of power to fire off both compressors and fans at the same time. Probably tripping your main breaker. . . Unless you arranged for some type of
a start delay on one of the units.
Stormy Dayton is offline   Reply With Quote
Old 06-13-2021, 05:20 PM   #7
Make sure the new thermostat has 2 zones.
Jdb95650 is offline   Reply With Quote
Old 06-20-2021, 07:49 PM   #8
Terrible
My stepfather added a wing to the house with separate heating and the installers put both thermostats and ducts from both thermostats in the living room. In the winter, the kids' rooms were always very cold. If we raised the thermostat, the master bedroom didn't heat and we caught heck.
Larry
Larry-NC is offline   Reply With Quote
roo, roof, thermostat
