02-06-2018, 05:58 PM
#21
Dahagen
If you are on AC, just buy a trouble light with an old incandescent bulb (not LED) and run it into your outside compartment with water controls and leave it on.
02-06-2018, 06:15 PM
#22
It’s a travel trailer
The majority of the water pipes are inside. Those that are not are under the trailer. Not in a compartment.
02-06-2018, 11:24 PM
#23
Just wire power to the blower motor directly using a relayed switch. Very easy to do it and won't involve much work. I'm actually thinking about doing this mod myself so I can circulate air when I'm using an electric heater and my portable propane heater at the same time.
02-06-2018, 11:51 PM
#24
after you have gone thru all the trouble to make this work consider the temp of the air you are trying to suck into the fan and move it to duct work and the fact that it has to heat up the ducts to have enough to transfer heat to your belly area. Do you really think there's a chance this will work?? You'll be better off to run your furnace. It would probably work for cool air in the trailer. IMHO
02-07-2018, 09:14 AM
#25
Next time I am in the MH exercising the Generator I will try to run fan without heat !!!
02-07-2018, 09:21 AM
#26
Right... and don't forget to report back. If your experiment works, please post a pic of your thermostat settings.
02-07-2018, 09:37 AM
#27
I will report back !!!
Don't think I know how to post photos,,, have tried in the past with no luck !!!
I know our thermostat is digital,,, and has fan settings of On - Off & Auto ???
It is Black,,, Standard 2013 Thermostat I believe !!!
02-07-2018, 09:41 AM
#28
If your thermostat is like the majority of ours, your FAN settings control the blower in your ceiling mounted air conditioner and doesn't have any effect on the furnace blower.
For tried and true instructions for posting pics here, see post #7 in this thread ===> http://www.forestriverforums.com/for...sics-6778.html.
02-07-2018, 10:09 AM
#29
Your probably right Dan !!!
Sure the way it should work !!!
LOL !!!
02-07-2018, 10:12 AM
#30
LOL !!!
Right... operative word is SHOULD!
02-07-2018, 10:17 AM
#31
I thought maybe we could turn Furnace on,,, set it @ the temp in our units,,, like if it were 60 set it @ 60 or 61,,, then when the furnace comes on,,, set the fan on,,, not auto !!! Guess I was dreaming ???
02-07-2018, 10:44 AM
#32
The fan in the furnace is controlled by the furnace control board. It has many built in safety features as you do not want the furnace running with the fan off. With manually modifying ( adding a bypass switch) you will not be able to run the fan from the thermostat.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
02-10-2018, 03:48 PM
#33
54 Years, 13 RV's
I installed a 10 amp switch with 14 awg wire between the power and blower terminals on the board of my Suburban 20K furnace. One terminal goes to the blower and the other terminal goes to power. It works PERFECTLY. One thing to note is, if you are in the blower "on" mode, the normal furnace mode won't work. You have to turn the blower "on" mode off, then it works normally.
I spent HOURS of frustrating time messing with relays, switches etc., but could not get the burner to come on in the blower "on" mode.
It did, however, accomplish what you are trying to do.
If anyone has a working mod that lets the furnace burner come on and go off with the stat, I'd love to try it.
2021 Rockwood 2511S
2020 GMC 1500 6.2L
02-10-2018, 04:58 PM
#34
I haven't played with my furnace first-hand. However, I believe the attached will work as you want, if your furnace is wired as I think it is. It looks like you should have +12VDC to the furnace continuously, with the power to the T-stat coming off that; so you can use that for the "continuous +12VDC you'll need. See page 31 in the attached service manual.
2011 Traverse LT, 3.6L, FWD
02-10-2018, 07:08 PM
#35
54 Years, 13 RV's
One of several versions I tried with no joy.
2021 Rockwood 2511S
2020 GMC 1500 6.2L
02-10-2018, 07:10 PM
#36
54 Years, 13 RV's
It looks totally right on paper but not in real life.
2021 Rockwood 2511S
2020 GMC 1500 6.2L
02-10-2018, 07:21 PM
#37
What about wiring it so it is turned off when the thermostat commands the heat on?
02-10-2018, 07:57 PM
#38
54 Years, 13 RV's
That would turn on the blower just like an aux switch, but would either have the burner on all the time, or require a gas valve off switch. I want full blower, and burner off and on with the stat.
2021 Rockwood 2511S
2020 GMC 1500 6.2L
02-10-2018, 08:44 PM
#39
What I’m saying is using a normally open relay controlled by a switch to bypass the control board and supply power to the blower.
Then using a normally closed relay that is controlled off the the thermostat heat command to the furnace. This relay switches the command to the other relay.
So it would have a manually controlled blower on switch that as soon as the thermostat commands the heat on it goes back to unmodified as far as the furnace is concerned.
02-10-2018, 08:46 PM
#40
54 Years, 13 RV's
Hmmmmmm
2021 Rockwood 2511S
2020 GMC 1500 6.2L
