Old 01-05-2021, 04:30 PM   #1
JWood422's Avatar
Can this really be correct on my fridge?
Im on hold waiting on Dometic support even as we speak. The pictures show the outside access to my Dometic DMR702 refrigerator. The top access is half blocked by what looks like interior paneling. Since hold times can take forever, should I cut that to allow more air flow?Click image for larger version
JWood422 is online now   Reply With Quote
Old 01-05-2021, 04:40 PM   #2
You could check the installation directions for that refrigerator model and see if it was done properly in terms of air flow area and obstructions.
Try here: https://www.dometic.com/en-gb/uk/sup...-documentation
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
BehindBars is online now   Reply With Quote
Old 01-05-2021, 04:51 PM   #3
Just as confused as you
Scrapper's Avatar
Do not cut the panel. It is made so the air is forced past the fins. If you remove any of the panel you will reduce the amount of heat removed from the fins thus reducing the efficiency of the fridge. If you look close you can see the top of the fins. Some have added an extra 12vdc computer fan with a built-in thermostat to the top of that panel to help with air flow. Just run the wires down to the 12vdc terminal block at the bottom.
What problem are you having with your fridge?
File Type: pdf Dometic-DMR-DMC-Refrigerators-Manual-Web_29111.pdf (3.47 MB, 31 views)
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
Old 01-05-2021, 05:05 PM   #4
JWood422's Avatar
Thanks, yall. The freezer cooling is erratic. Sometimes it freezes great sometimes not much at all. I just got off the phone with Dometic. Shes gonna find out for sure and call me back. I havent cut anything, yet. Ill let yall know what she says.
Thanks!
Old 01-05-2021, 05:35 PM   #5
rracer5's Avatar
There are VERY SPECIFIC instructions dictated by Dometic that the manufacturers must follow when installing specific models. Instructions include space dimensions and location & angle of air flow baffles to optimize air flow over the cooling coils.
I have seen installs that look similar to yours.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 01-05-2021, 06:04 PM   #6
Scrapper's Avatar
Thanks!
Try the extra fan installation, just make sure the fan pushes the air out the top louver.
Richard & Jill
Camping since 1989
Old 01-05-2021, 06:11 PM   #7
X2 what scrapper said. Do Not Cut!
I did cut a small hole and placed a square computer fan in my baffle, blowing out the top vent. Helps remove the 'trapped' air at the top of the compartment and helped cooling.
Days Camped: '18=51 '19=58 '20=110 '21=60
Old 01-05-2021, 06:18 PM   #8
I did this, installing a pair of Titan fans with automatic controller on the top vent (Mines on the roof) and a DIY fridge fan made of a couple computer fans.
Both fridge and freezer now hold nice and steady with freezer between -5 and +5. Fridge sits solid at 35 degrees.
A great mod that works even when outside temps are over 100 degrees.
FWIW, the Titan Fans (available on Amazon) have a controller that automatically senses temp in the heat shedding coils, adjusting the fan speed for max effect as well as lowest necessary current draw. Total current draw on high is around 1/4 amp.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 01-05-2021, 07:13 PM   #9
JWood422's Avatar
Scrapper was absolutely right! I got an email back from Dometic saying not to cut it. She wrote it in all caps. So, no cutting will be done by me!
Ill check in to the fans. Thanks for the help, yall!
Old 01-05-2021, 07:40 PM   #10
larry2c's Avatar
Hey Scrapper - are these the fans you got? Click here
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Two shedding mutts
larry2c is offline   Reply With Quote
Old 01-05-2021, 09:22 PM   #11
You may not need any fans. We have not added any fans and our refer stays cold even in 90-100 weather.
MtBiker is online now   Reply With Quote
Old 01-05-2021, 09:32 PM   #12
Don't know about Scrapper but this is the fan set I got.
2004 Nissan Titan
Old 01-05-2021, 09:48 PM   #13
We have a Dometic 2-way and if anything it stays too cold. No need for fans on mine.
Old 01-06-2021, 11:22 AM   #14
Scrapper's Avatar
I never had to add fans to my fridge as the original fan seems to do a good job. The TT is in a wooded area and we never experienced erratic temperature swings in the fridge. I periodically check the temperature with a HVAC thermometer that I found in a HVAC service van we were about to send through the car shredder.
Name:	HVAC Thermometer.jpg
Richard & Jill
Camping since 1989
Old 01-06-2021, 12:47 PM   #15
Forest River (at least Flagstaff and Rockwood in my experience) do a very poor job of following Dometic instructions for installing Dometic fridges. In my 2 A-frames, I have seen the following installation errors:
- failure to seal off the sides of the fridge with insulation
- failure to seal off the top of the fridge with insulation
- failure to have the top of the top vent at the top of the fridge compartment. this creates a dead airspace full of hot air.
- propane exhaust is aimed at the back of the fridge instead of the top vent
- baffle wrong size, and not installed at the correct distances from cooling fins
- propane fume outlet (also used for fridge water drain) in floor of compartment covered with hoses and wires
The closer you can bring your installation to Dometic installation specs, the better it performs.
There is still the problem that the plastic Dometic side vent grills that Forest River uses can't pass gas in a hurricane. They are great for making sure sideways rain never enters the fridge compartment, but they are also great for making sure the heat never escapes the fridge compartment either. I install computer case fan(s) - 12V, low RPM, 120mm, 400+CFM, 70-80ma directly on the back of the fridge top vent grill to blow the heat out. They work great; I have a manual switch inside the camper for simplicity. With these fans, the noisy factory fan below the baffle never comes on.
I also use a little D-cell powered fan inside the fridge to just barely circulate the air. With the fan mods, the fridge now works great in any temp we are willing to camp in.
https://www.forestriverforums.com/fo...ge-104964.html contains the details of my quest to get consistent fridge performance in any weather.
Fred W
2019 Flagstaff T21TBHW A-frame
pgandw is online now   Reply With Quote
Old 01-06-2021, 12:50 PM   #16
rracer5's Avatar
Just before I replaced my Dometic with a residential (DW wanted a larger capacity), I found the fans installed either by Dometic or the coach manufacturer had shorted and blown the inline fuse. I never noticed any difference in the performance of the fridge. Don't even know how long it was blown!
So, check to see if you have any fans already installed & see if they're working. Mine were installed near the top coils & I could only "see" them after removing the fridge when I replaced it. You may be able to see them with the assistance of your phone camera.
2014 Sanibel 3250
Old 01-06-2021, 01:40 PM   #17
SlowrideHD's Avatar
I replaced the original condenser fan in my fridge because it was noisy every time it ran. I bought two 120mm super quiet computer case fans and installed them, one wired into the original electric path to the thermistor on the condenser, the other on a manual switch that I could turn on if needed.
To do the install, I had to remove the Luan panel that restricts part of the upper vent opening. Whether its from increased airflow from the improved fans, or just the larger opening, I don't know. But I did the install probably four years ago and have had excellent performance from my fridge ever since. Even in Az heat, I have never had to manually turn on the second fan.
I am not convinced the restricted vent opening to direct the airflow over the fins is helpful. I'm sure it was tested that way and verified (under a lab condition, most likely).
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
SlowrideHD is offline   Reply With Quote
Old 01-06-2021, 02:28 PM   #18
if you cut it to put a fan or fans in aren't you still breaking the integrity of what she told you to leave as is?
Or maybe the fans are going somewhere else?
campers302 is offline   Reply With Quote
Old 01-06-2021, 03:47 PM   #19
Scrapper's Avatar
If there is enough space to fasten the fans to the panel there is no need to cut it. Though you may have to make some holes to attach the fans they would not effect it much.
Richard & Jill
Camping since 1989
Old 01-06-2021, 04:23 PM   #20
JWood422's Avatar
Just so everyone will know, Im not planning on making any changes to the fridge anytime soon. I have a feeling the freezer takes longer than most to stabilize after being defrosted. I woulda thought that after 4 days it would have been perfectly cold. It seems to be perfectly cold now. Or at least it was yesterday.
My biggest reason for starting this thread was it looked just plain wrong to me. As it turns out, looking just plain wrong is just plain right!
fridge
