Old 10-27-2012, 05:59 PM   #21
dashonthedash's Avatar
LF, did you try rotating your antenna? Also, have you checked the coax connection to your TV to see if it's loose?
Gary Shapiro, 2011 Georgetown 29' Class A
Dash, Molly & Lily - now at the Bridge and forever in my heart
Shadow - 4-year-old Greyhound
Hannah - 1 1/2-year-old GSD rescue
dashonthedash is offline   Reply With Quote
Old 10-27-2012, 06:01 PM   #22
Thanks, Gary -- yes to both. What's wierd is both tv's do the same thing -- search for channels without success. Anyway, thanks for responding. larry F
LFineg is offline   Reply With Quote
Old 10-27-2012, 06:10 PM   #23
Road-King's Avatar
Originally Posted by LFineg View Post
Thanks, but I had done that. LF
You said you checked all antenna connections, just to make sure, did you check the ones behind the amp switch plate, also there may be a splitter behind the switch plate as well and a connection on the roof at the antenna... Other than that I don't know, maybe a bad amp????
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 10-27-2012, 06:16 PM   #24
Well, I can think of only three other possibilities: either your signal is being blocked somehow, the cable is broken somewhere between the antenna and the outlet, or your amplifier (booster) is busted. A little troubleshooting with a DVM may be in order.
Old 10-27-2012, 09:23 PM   #25
Dear Russ & Kim & Gary-- I'll try some more trouble shooting to see if any of these leads check out Thanks Larry F
