Not a 15 min install like the Furrion, but about $300 cheaper. Our E-Pro has the Furrion pre-wire setup that powers on with the driving lights. Biggest issue was the 10 feet of wire the camera comes with, as it's intended for a trunk install, I shortened the power wires but was hesitant to cut the black camera wire so I wound it up inside the Furrion housing. Did some selective Dremel mods to the inside of the housing to fit the antennae module. Tested the range using a 12v power supply before I started modifying things, first from the bathroom in the back and then behind the trailer on the ladder. There is another camera on Amazon that's 200 something, that is more like the Furrion, with the antennae to the side.
Product:
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
$138 with tax after a $20 coupon.
