Originally Posted by Oaklevel
The coax on the drivers side of the trailer should be the cable / satellite "in" access.
The coax on the curb side of the trailer should be the cable / satellite / antenna out to the tv.
There should be a small box inside usually near the main tv location with a small switch to change from cable to antenna.
No idea what a composite output is, Picture?
What the OP calls a composite video connector is what the rest of the world calls an "RCA jack." One of the common places you used to see these was in a three signal yellow/red/white cable set, where yellow was composite video, and red and white were left/right channel stereo audio.
If there's just one jack, it might be mono audio coming from the entertainment center, not video. I always say, "If you haven't put your oscilloscope on it, don't guess what it is."
But you can actually detect the audio with an AC voltmeter or multimeter on the AC scale. Put on some music with a loud beat and you can actually see the needle on an an analog meter swing with the beat.
