Old 08-22-2009, 01:39 PM   #1
Question concertone removal
Can anyone explain how to remove my audio system from the cabinet it is in.
The model is Dx600 the only thing i could get off was the clear plastic cover.Some one told me to pry off the cover with a putty knife,any detailed info. would be appreaciated.
Thank You
Tom
wizard is offline   Reply With Quote
Old 08-22-2009, 04:46 PM   #2
KyDan's Avatar
Mine has a trim ring around the edges.
I pried that off and that exposed screws around the edge that
I removed and pulled out the unit. I don't have a 600 tho......
YMMV.
Good luck!
Peace!
Dan & Rita D
Old 08-22-2009, 06:54 PM   #3
Unfortunately I have the 600 and I've had to remove it enough times I could do it in my sleep.
You need to pry off the cover with a small screwdriver or putty knife. Then there are screws that need to be removed. Once the screws are out you just pull the unit out from the wall. There are miles of wire. Good luck.
8261ss is offline   Reply With Quote
Old 08-23-2009, 09:37 AM   #4
Yes, I too have the ZX 600, and there is a serious rat's nest of wires behind the unit! If you pull off the outer trim cover around the unit- it will come off with a putty knife, or a butter knife, then you'll see the screws holding it in. GOOD LUCK!!!
Old 08-25-2009, 05:54 AM   #5
Thank you every one for the tips on how to remove the concertone i will try these methods.
