Convert from 15k Dometic to Mach 15 without changing thermostats?
Hi All, I have a 2018 Shockwave with a 15K Dometic AC unit. The thing works ok when it's like 75 degrees but past 80 and it's done (starts blowing warm air). Sure it's under warranty but my dealer has tested it on 2 different occasions and he says it's just fine. I have also called Dometic and they were no help. I told them I heard there were a number of 15K units that were undercharged from the factory and they admitted that there were some but after checking my serial number, they said mine was not one of them.
So My question is, can I convert to a Coleman Mach 15 without changing thermostats? I see that there are conversion kits to go from a Coleman to a Dometic but I don't see any that go the other way.
I am also considering adding a port to the Dometic and see if that helps it work better as I have a friend who has the tools to pull a vacuum then recharge. Yes I am aware that would void any warranty but the warranty seems to be useless in my case.
Thank you for any help.
2012 Ram 3500 Megacab SRW 6.7L Cummins
