Old 10-01-2023, 12:01 AM   #1
Converter Fan Cycles
When I turn on the light on my stovetop hood, the converter cooling fan cycles on and off. No other light in the camper seems to do this, any thoughts? Gene
eugene hickok is offline   Reply With Quote
Old 10-01-2023, 12:53 AM   #2
bikendan's Avatar
Have you checked the battery's charge with a multimeter and without being plugged into shore power?
Generally the converter fan will run constantly if the battery is bad.
Old 10-01-2023, 03:55 AM   #3
The converter issue happens while plugged into shore power.
Wet
Old 10-01-2023, 04:21 AM   #4
bikendan's Avatar
That's because the converter only works when plugged into shore power, in order to recharge the battery. If you're NOT plugged into shore power, the converter doesn't work.
Old 10-01-2023, 07:45 AM   #5
Check your lights. My hood light was incandescent and suck more power than 4 of the LED lights on the ceiling. Could be the higher current triggers the fan circuit.
2019 Palomino Solaire 147X
2013 Ford F150
TacomaJoe is offline   Reply With Quote
Old 10-01-2023, 07:53 AM   #6
PhilFromMaine's Avatar
Exactly! If a well functioning converter is using the cooling fan it means it is working hard to supply 12V power. It could possibly mean that the battery doesn't have enough stored 12 volt power to run the TT and you are relying on the converter too much to make up the difference. There is a lot of "ghost" 12 volt drain on a battery and turning on the lights may be the straw that broke the camels back.
Most often it is the battery that is the root of 12 volt power issues.
2018 Coachmen Freedom Express Liberty Edition 231RBDSLE
PhilFromMaine is offline   Reply With Quote
Old 10-01-2023, 08:14 AM   #7
is the light above the stove connected to a stove fan as well?
I'd rather see the converter fan come ON.... than stay OFF
converter will decide when it needs cooling...
unless the fan is noisy ... no big deal if it is running or not
the fan is not going to drain the battery cause you are connected to 120v
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 10-01-2023, 09:04 AM   #8
X2
Mine comes on and off as needed as far as I have noticed. I think even ambient temperature is a part of it. Do not run the air a lot and converter fan was on yesterday afternoon after dumping my tanks and moving a spot over and is off this morning.
2022 Rockwood 2511S
2018 F150 3.5 Crew Cab 4x4
Max Tow Package 1855 Lbs Payload
Husky CenterLine WDH
GolfingDave is offline   Reply With Quote
converter, fan
