Old 06-06-2022, 09:32 PM   #1
countertop icemaker recommendations?
I plan to redesign my outdoor kitchen. That plan includes a countertop icemaker, the existence of which I only learned recently when I saw one in a GeoPro. For those of you that have experience with one, would you recommend the one you have?
I expect to use it only for drinks. If I have shore power I might make use some in a lunch-sized ice chest. My criteria for evaluation includes size and how the ice dispenses. The ideal location in my outdoor kitchen would put it at least partially under a shelf. If I can unload it from the front, or if the top is hinged halfway with the front opening tilted forward, that would be great.
As I will be using this intermittently with an inverter, power consumption is also useful information. I'm not concerned so much with absolute wattage as I am with how efficiently it produces ice with the wattage it consumes. I will compare the amp rating to the claimed rate of ice production to make that assessment.
TV: 2016 Ford F-150 SCrew EB RWD Lariat MaxTow
RV: 2020 Rockwood Mini-Lite 2507S
chriscowles is online now   Reply With Quote
Old 06-06-2022, 09:46 PM   #2
nvs4602's Avatar
My brother has a Winnebago Tour in one of the pull out bins underneath he installed a regular restaurant size icemaker and plumbed it in along with a filtration system. He always has plenty of ice. The counter top are nice but I would want one that's plumed in not one you have to fill with water by hand.
nvs4602 is offline   Reply With Quote
Old 06-06-2022, 11:14 PM   #3
An icemaker small enough to run off an inverter would be a big convenience for occasional use. I have space only for a countertop model.
Old 06-06-2022, 11:35 PM   #4
Our Frigidaire countertop icemaker is reported to use 100 watts occasionally spiking to 140 watts. It uses a standard refrigeration cycle with a compressor, so about the same as a small size refrigerator. It holds enough ice for probably 6 glasses.
NavyLCDR is online now   Reply With Quote
Old 06-07-2022, 10:52 AM   #5
We absolutely love our Opal Nugget ice maker, and wouldn't hesitate to buy another. Ours is an older unit, but they have several models now and I really like the one with the dispenser.
Gotta go campin!
Old 06-07-2022, 11:12 AM   #6
rlsmith's Avatar
Our counter top unit gets used everyday we are camping and happy to have it. Yes sometimes it has a hard time keeping up but every 3 minutes it makes enough ice to keep a drink cold, unless the drink has been sitting in the heat. Matter of fact we like them so much we have one for our home. We shut ours off before going to bed and start it in AM when making coffee. Blow the dust out every year and we take ours in the house over winter. Its ours is 8 yrs old this year.
Days Camped: 2014: 24-(final), 2015: 19 (Final), 2016: 31 (final), 2017: 10 (final ) 2018: 32 (final), 2019: 22 (final),2020 covid: 44 (final), 2021: 12
rlsmith is offline   Reply With Quote
Old 06-07-2022, 11:23 AM   #7
bob213's Avatar
Ours works great, can't remember the brand. It seems like there is about three mfgs. that make all of them and rebrand them under several names. No need to spend a lot of money on one. Keep in mind that they do not "keep" ice. If you don't remove it and use it or store it in the freezer it will melt and be remade.(most counter top models)
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
bob213 is offline   Reply With Quote
Old 06-07-2022, 11:42 AM   #8
Based on your mention I just looked at one online. I like the front-opening ice bin and reservoir but the machine is larger than I prefer for our trailer. It's also expensive and draws more power, relative to other (perhaps lesser) options.
Old 06-07-2022, 11:46 AM   #9
llr
We have a countertop model we got 2-3 years ago from a big box store, use it every trip.
The only "issue" we have had is occasionally our filtered water is too clean and it thinks it is empty. Add about a cup of tap water or a little more bottled and back in business
TT 2021 Grand Design 2800BH
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
prior TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 06-07-2022, 11:55 AM   #10
Originally Posted by rlsmith View Post
Our counter top unit gets used everyday we are camping and happy to have it. ...
Originally Posted by bob213 View Post
Ours works great, can't remember the brand. It seems like there is about three mfgs. that make all of them and rebrand them under several names. ...
Do you have any concerns about vibration damage while traveling? I'd think not any more than with a standard compressor refrigerator?
I'm looking at a Silonn brand device on Amazon for <$100. It's only ~12" deep and high, ~9" wide, and the top hinges in the middle. I could mount it partly under a shelf without having to move it, as long as I can get to the buttons and open the top completely. The specs show it draws ~200W while making ice and ~230W while "harvesting" it. (I'm guessing the surge is the motor that pushes the ice into the bin.) I'll have to take side and rear clearance into consideration but 3" isn't much.
I can't start on my kitchen redesign until we return in mid-July but I'm accumulating ideas. Thanks for your help.
Old 06-07-2022, 11:56 AM   #11
That's on the low side of power consumption. Can you provide a link?
Old 06-07-2022, 11:58 AM   #12
That suggests the sensor is based on conductivity. That's interesting, considering that filtered water is recommended to prevent mineral buildup.
Old 06-07-2022, 12:10 PM   #13
llr
Yes it is. When I stuck my meter leads in it read open or close to it, I forget exactly. Pure water is actually a pretty good insulator. It takes very little minerals to be conductive. This has only happened a few times, generally it is not an issue. Although the 1st time I thought the unit failed and it took me awhile to figure it out.
Old 06-07-2022, 12:22 PM   #14
I've seen Amazon reviews of some models where the users complain about false "add water" alerts. It sounds to me like that's the problem.
Old 06-07-2022, 02:13 PM   #15
jeff64's Avatar
I would be surprised if all these icemakers don't come out of the same factory. The Home brand which I have seems to work fine. Whether for drinks or use in a small cooler. The cubes, I collect and put in my freezer to harden and they'll last longer. Occasionally I have had to unplug it and "reboot" it. Not a deal breaker
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 06-07-2022, 02:18 PM   #16
Originally Posted by jeff64 View Post
... Whether for drinks or use in a small cooler. The cubes, I collect and put in my freezer to harden and they'll last longer. ...
That's how I anticipate using it. If not on shore power, make a batch and put them in the freezer of our 2-way refrigerator for use as needed, then shut it off.
Old 06-09-2022, 09:56 AM   #17
Retired Panpsychist
Theo's Avatar
I've found the recommendations from Jared Gillis (All About RVs) are usually quite reliable. In the description of the video below, he recommends the following two models:
Frigidaire EFIC189
Frigidaire EFIC101
Here is the video in which he mentions the EFIC189. Go to the 0:42 time mark:
Theo & Carol
2007 GoldenDoodle ("Cooper")
2020 Rockwood Roo 23IKSS
2015 F-150 4WD XLT SCab, 5.0L, 3.73, 36gal, HD Towing Pkg (53A), 1,980lb Payload
Theo is offline   Reply With Quote
Old 06-09-2022, 10:56 AM   #18
RV There Yet?
IsleDog's Avatar
the link is the exact model we have had for 2 years now. we dont leave home without it. we have a VERY small fridge with freezer inside it and this unit keeps up with ice for the cooler and drinks on top of that. It has more than paid for itself in us not having to buy ice all the time. keep in mind that these only make about 1lbs of ice per hour, and you have to keep on top of emptying the basket or it will stop working until it melts back into the water revivor.
https://www.amazon.com/FRIGIDAIRE-EF..._id=2399939011
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
IsleDog is offline   Reply With Quote
Old 06-09-2022, 12:24 PM   #19
I have an igloo one and it works well however when the temp reaches 80 outside we move it inside with the AC going. Above 80 and it takes longer for the ice and the cubes are smaller.
Capacitor is online now   Reply With Quote
Old 06-09-2022, 12:29 PM   #20
Rhumblefish's Avatar
Thanks a lot, guys. Yesterday, I lost a couple of hours investigating countertop icemakers.
Common sense smacked me in the forehead this morning, suggesting I just use some ice cube trays in the freezer for the time being... but man, I sure do like me the idea of some fresh Sonic ice whilst out boondockin.
Cheers!
2022 Rockwood Roo 235S
2017 Audi Q7 3.0 Prestige w/air (yes, it actually tows that)
WeighSafe hitch - no WD or anti-sway
Rhumblefish is offline   Reply With Quote
