Old 06-10-2017, 06:15 PM   #1
distorted ceiling speakers
a year or so ago installed two alpine speakers in ceiling to replace stock. they worked fine until recently when they have become distorted. when removed from ceiling there was a fair amount of white styrofoam ceiling insulation deposited in the speakers. could this be the problem?
flugelboneman is offline   Reply With Quote
Old 06-10-2017, 06:22 PM   #2
Kanadian Kamper
kenandterry's Avatar
Distorted speakers is a personal definition.
You mention the excess styrofoam. Could it be the styrofoam was bouncing on the speakers causing your distortion? Try them before installing again to see if there's distortion. Then reinstall and try again.
Ken and Terry
2018 Sunseeker 2430S with Trekker cap
and only rarely pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 06-10-2017, 06:46 PM   #3
thx kenand terry
its cud well be the styrofoam is bouncing off the speakers. my problem is that there was styrofoam incursion in and on the speaker. little tiny pieces. my question is an attempt to determine if such foreign matter is present, wud this effect the performance of the speaker. my next step will be to take the speakers down, vacuum the particles off and then place some kind of baffle between speaker and insulation. before i go to this trouble wud like someone who is familiar with speaker technology to give an opinion. these are expensive alpine speakers so am very disappointed.
Old 06-10-2017, 07:02 PM   #4
Kanadian Kamper
Many many makes and models of RV's have styrofoam in the ceiling as part of assembly. It may be in larger solid pieces and is trimmed and cut as needed when certain items are installed in the ceiling. It's all part of creating insulation for the living quarters.
Even in our rig after 7 years, I still find particles falling from time to time.
Ken and Terry
Old 06-10-2017, 07:09 PM   #5
Location: Minnesota ( wishing we were boondocking in the New York Catskills )
Parts Express, and MCM Electronics, among others, can sell you foam baskets that go behind the speakers and protect from falling / bouncing crud.
Jeff and Abby
Fur Babies - Xandra Sophia (GSD) and Neo (Min-Pin Mutt who thinks he is a cat)
2015 Tracer Air 235 (previous 1994 Veri-Lite 1130 TC)
1998 Dodge Ram 2500 Quad Cab - 360 - 46RE (Built)
Jeff_and_Abby is offline   Reply With Quote
Old 06-10-2017, 07:50 PM   #6
Flybob's Avatar
Foam pieces bouncing on the speaker cone will cause distortion.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-10-2017, 07:57 PM   #7
distorted speakers
thx guys for all the helpful replies. will look into that speaker basket. do u think if i carefully vacuum the speakers it will remove most of the particles.
Old 06-10-2017, 08:14 PM   #8
Use a long-bristle brush on a hose-type vacuum and you will do fine. The speakers are probably connected with push-on terminals, so you could also carefully remove them and then use a clean, dry paintbrush or make-up brush. (The little fibre board that they are attached to the speaker from upon, is likely fragile - brittle from age, plus the nature of speaker terminals.) If the speakers have an obvious "foam" outer edge, just be gentle. These usually have a life of ten-plus years if not exposed to direct sun. They are repairable / replaceable if damaged.
Jeff and Abby
Old 06-10-2017, 10:27 PM   #9
distorted speakers
thx again jeff. i replied via ur pvt email and got a message from fr forums saying thats a nono. what i replied is i will acquired a couple of speaker baskets used to protect speakers from insullation in ceilings. then i will follow ur very good suggestions regarding cleaning.
Old 06-10-2017, 10:45 PM   #10
Hopefully getting the foreign objects off the speaker helps if not check the impedance of the speaker it should match impedance of the amplifier if not that could be the problem.
Fly YX is offline   Reply With Quote
Old 06-11-2017, 04:05 PM   #11
distorted speakers
roger that, will chek impedance. hope it is just the styro tho
Old 06-14-2017, 10:21 AM   #12
"Damn," should have mentioned this sooner ...
a slick "quick fix" is to wrap the entire speaker in a used pantyhose - the material is acoustically transparent, and will keep dust and particles away from the speaker.
Jeff and Abby
Old 06-14-2017, 02:18 PM   #13
distorted speakers
hi fly vx and others giving me help on this vexing problem. cleaned both speakers and put bathing caps over speakers to protect from styrolfoam. put them back together only to discover one speaker still distorted. think perhaps it is faulty, or permanently damaged by foam incursion as mentioned by one. we are on road now but once back home will return speaker in the hope of getting a replacement.
Old 06-14-2017, 02:45 PM   #14
Kenny kustom's Avatar
Distortion is caused by under powering the speaker. The voice coil looses control.
When you upgraded to the alpine speaker, they have a larger voice coil than the stock speaker. But were still being driven by the low wattage head unit.
Think 4 banger in a civic. Motor matches car. Now, you took the 4 banger out of the civic and put it in a dually.
2017 Dynamax Isata 4
Old 06-15-2017, 09:47 PM   #15
distorted speakers
hi kenny kustom
thx for info. jensen amp is plenty wattage for alpine speakers. after cleaning, i find one is the distortion culprit. the other speaker boom out with authority. i think the one distorting speaker may be faulty. i am hoping if i take it back to my hi fi guy, he will test it and hopefully replace it.
Old 06-15-2017, 11:02 PM   #16
What's the specs on the Jensen and the alpine?
Old 06-15-2017, 11:29 PM   #17
From the Jensen manual, it puts out about 8 watts. Click image for larger version
