Your air conditioner will only cool the intake air 18 to 20 degrees. So, if the air entering your AC is 100 degrees, you will be lucky if the air coming out is 80 degrees. Something else to consider, your RV has thin walls, perhaps two inches thick, a ceiling that does not contain much in the way of insulation and walls with huge windows. Our 32ft. 5th wheel came with one 15K air conditioner, I added a second 15K which helps, but on a very hot day, the two running has problems keeping it as cool as I would like.
