Dometic 2652 - Fridge Too Cold...System Board?
We're getting fridge temps down below freezing, into the high 20's!!
I've completely checked the thermistor and using an abundance of caution, replaced it with another working one. Was tested with the factory resistance test procedure. Also, Thermistor position does not change temp.
So I think we are down to a faulty system board. Any disagreement? Has anyone replaced the system board to remedy, and were you successful? Anyone use the aftermarket Dinosaur replace board?
Thank you - Dave
2019 NOBO 19.7 - Dual Propane, Dual GC Batteries,
EMS, Auto Transfer Switch, 3000w Inverter (properly installed!)
2019 Ford Expedition Max, payload ~ 1700
