Old 06-10-2018, 09:42 PM   #1
Dometic 3962 water dripping behind fridge
I just happened to remove the lower exterior panel of our slide-mounted dometic fridge today to check on the drain hose today. We had just returned from a weekend outing and noticed water puddling below the power module.
Here are pix:
the control module (bottom left, lower exterior panel removed)
Water puddling on fridge compartment floor on left and right side of left side Fridge mounting bracket
Drip coming from behind power control module
Water puddling on DC terminal board
Water puddle left of fridge mounting bracket getting insulation wet and presumably will rot the bottom of the slide
Drip hose attached to back of fridge...looks like it wasn't sealed very well
I am only aware of one place water would be coming from the exterior of the fridge rear side and that is the drain hose. This would require pulling the fridge out to get to where the hose is connected to the back of the fridge.
Any other suggestions for where to check for leaks?
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 06-10-2018, 09:52 PM   #2
rk06382's Avatar
Originally Posted by chaps2018 View Post
I just happen to remove the lower exterior panel of our slide-mounted dometic fridge today to check on the drain hose today. We had just returned from a weekend outing and noticed water puddling below the power module.
Here are pix:
That is your drain hose. It is supposed be in the vent of the exterior panel to drain outside of your RV.
Robert
2018 FR3 28DS | Boondock 90% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks
Solar Power & Battle Born batteries
rk06382 is online now   Reply With Quote
Old 06-10-2018, 09:59 PM   #3
Originally Posted by rk06382 View Post
That is your drain hose...
Thanks, but while hard to see, that is the 120V power cord going to the power control module.
Just to confirm, the drain hose is not in any of these pix but is routed to the exterior vent panel.
Old 06-10-2018, 10:38 PM   #4
rk06382's Avatar
Make sure the roof vent is intact.
The drain hose attaches to the bottom of the white drip tray inside the fridge. If it is connected then you should be able to pore water on the tray and it should come out the drain hose outside. If it goes outside then the drain hose is not the source of the water.
Robert
Old 06-10-2018, 11:20 PM   #5
Excellent suggestion. After things dry out a bit I will have DW pour water in the drip tray and I can observe outside. I will report back in a few days.
dometic, water, fridge
