Dometic AC 15K won't stay on low fan when cooling
With the thermostat set 1 degree lower than camper internal temp, why will it not stay cooling on low fan with the setting on low fan? It randomly kicks out the compressor and cycles the fan to high, then back to low fan with the compressor. This habit continues until I switch the fan to high.
I just replaced the thermostat and AC controller in hopes to fix this but no luck.
Coachman Freedom Express 320BHDS
