Old 09-03-2019, 07:21 AM   #1
Smile Dometic AC Issue
I have a 2016 Columbus 340RKC 5th wheel with dual Dometic ac units. The front is a 13.5K btu and the rear is a 15K btu unit. The last 2 times we have went camping the rear air just cuts off completely both the fan and the compressor. In about 30-45 seconds the fan will start and then another minute or so the compressor will start. It may run a few minutes or an hour or so and then it shuts off again, going through the same routine again. I have a dual zone Dometic thermostat, CCC2 and its not showing any error codes. The front ac runs fine. It seems to do it more in the daytime than at night. I guess it does it due to the heat of the day. Anyone have any suggestions as to what may be happening? Someone suggested low voltage but I have a high dollar surge protector and it has not tripped due to low voltage. The lowest voltage I have seen is 113V AC but normally it is higher than that.
krs2_us is offline   Reply With Quote
dometic
