Dometic AC knob stops
The problem is that the knob stops on the left knob which is the fan control have been broke since I purchased the camper used. This is the 30 amp unit in the bedroom which is controlled only by the two knobs in the roof unit. I have used the unit several Times, but apparently have turned the knob around so many times because of the nonexistent knob stops that it no longer works. I can no longer get the compressor to come on or get the unit to turn off (so have to turn it off at the breaker). I am guessing that I will need to replace the knob control assembly or something like that and curious how big of a job that is. The knob stops still work on the right knob which controls the temperature.
