Old 10-02-2021, 04:37 PM   #1
Ham Camper's Avatar
Dometic air and thermostat
As I was running my air in my Surveyor Cadet 265 RLDS travel trailer it suddenly turned off. The setting was low fan so it should keep running even when the compressor shuts down. No matter where I set the thermostat the air would not come back on. So I ran the thermostat through heat, air and all and the air started back up only to run perfectly for a while but shut down again. I am thinking the thermostat is the problem. The 15000 BTU air was working great. Has anyone else run into this problem??
Larry W8PO & Lori N8IHJ and Louie the wonder dog
2014 Surveyor Cadet 265RLDS
2015 GMC Denali HD
Ham Camper is offline   Reply With Quote
Old 10-02-2021, 04:50 PM   #2
Just Tryin' to Help
cboss's Avatar
Please post a pic of your thermostat.
Craig & Cath
2017 Ford F250 Lariat, 6.2 gas (2022 F250 Lariat 7.3 gas with 10 speed Xmsn on order)
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2015(retirement): 1050
cboss is offline   Reply With Quote
Old 10-03-2021, 11:30 AM   #3
Ham Camper's Avatar
I took a pic but not sure how to post it in a reply to you. I uploaded it to my photo gallery but do not know how to post it in a reply.
2015 GMC Denali HD
Old 10-03-2021, 11:34 AM   #4
Just Tryin' to Help
cboss's Avatar
Read post #7 in this thread.
https://www.forestriverforums.com/fo...sics-6778.html
Craig & Cath
Old 10-03-2021, 11:44 AM   #5
Ham Camper's Avatar
pic of thermostat
2015 GMC Denali HD
Old 10-03-2021, 11:45 AM   #6
Ham Camper's Avatar
I guess I figured it out
2015 GMC Denali HD
Old 10-03-2021, 12:52 PM   #7
I had a similar problem this Spring. The air conditioning worked fine, when it reached the set temp it turned off as it should have. When the camper warmed up it would not turn back on without my turning off at the thermostat and turning back on the AC. I cleaned the unit and checked the parts of the roof unit all were fine. Then I checked the wiring of the control unit (box) in the ceiling above the air filter, disconnected and reconnected the wires. The signal wire from the thermostat may have been lose, since plugging back in the wires in the control box we have not had a problem with AC coming on as it should. Good Luck, hope this helps someone else.
Frierson is offline   Reply With Quote
Old 10-03-2021, 01:56 PM   #8
Easier way
Originally Posted by cboss View Post
There's an easier way to post pictures.
  1. Put picture on your computer. Remember the folder (e.g., Desktop or Documents or Downloads).
  2. Start the post.
  3. Click the paperclip icon at the top of the posting editor. It's next to the smiley. A popup will occur.
  4. In the popup navigate to the folder and select the picture.
  5. Repeat the above step up to four more times.
  6. Click Upload
  7. Click Close Window
Larry
Larry-NC is offline   Reply With Quote
Old 10-03-2021, 04:43 PM   #9
Maybe the AC is freezing up because you are running the fan on low speed....this use to happen to us in our previous 5th wheel. We learned our lesson to never run the AC with the fan on low.
Mike K
2019 Cedar Creek 34RL2 w/disc brakes
2017 GMC 3500 D/A, DRW, 40Gal Aux Tank
USN 76-82
Retired Dept of Navy: Navy/USMC Flt Test Engineer
Splashes3 is offline   Reply With Quote
Old 10-03-2021, 05:32 PM   #10
Ham Camper's Avatar
It did it with the fan setting on high. I tried that too
2015 GMC Denali HD
Old 10-03-2021, 05:33 PM   #11
Ham Camper's Avatar
I will try that
2015 GMC Denali HD
Old 10-03-2021, 07:56 PM   #12
Tom48's Avatar
Seems like we used to have that thermostat. Though the operation or best advice was run only in auto.
Tom48 is offline   Reply With Quote
Old 10-04-2021, 11:04 AM   #13
Ham Camper's Avatar
Your advice is right on with the posting of pictures. Thanks a lot. With covid we have not been camping much so have not been on the FR Forum much and my memory about how to do things comes and goes.
2015 GMC Denali HD
Old 10-04-2021, 11:35 AM   #14
Quote
Ham, when you respond to a post here, click the "Quote" button at the bottom of that specific post. That puts the message you are responding to in a box above your response just like this message.
Posting as you've been doing makes it hard to tell who you are responding to.
Larry
Old 10-04-2021, 01:38 PM   #15
Ham Camper's Avatar
I am trying to navigate the best I know how and it ios not easy from what I can see
2015 GMC Denali HD
Old 10-04-2021, 05:33 PM   #16
Ham Camper's Avatar
I wondered what the quote thing was all about.
2015 GMC Denali HD
Old 10-04-2021, 06:04 PM   #17
Just Tryin' to Help
cboss's Avatar
You'll be a MOD some day!
Craig & Cath
Old 10-04-2021, 08:27 PM   #18
To the OP, you mentioned the fan continued to run with the fan set to low speed even when the compressor would turn off, that I would expect, does the fan shut off when it's set to auto? Also as I would expect, similar to a house HVAC...
My A/C fan does not shut off on any fan setting, auto or otherwise...
My heater does shut off when temp is reached, not the A/C
Thanks, Rick
Toy4Rick is online now   Reply With Quote
Old 10-05-2021, 06:40 AM   #19
Ham Camper's Avatar
LOL I doubt that
2015 GMC Denali HD
Old 10-06-2021, 09:02 AM   #20
Thanks, Rick
Thoughts on if the AC fan should turn off when temp is reached when in Auto mode?
dometic
