09-01-2020, 07:34 PM
Dometic DMR702 fridge failure... AGAIN!!!!!!
Any assistance would be very appreciated....
Fridge wont cool on Auto or LP.... no clicking trying gas
Normal lights on the board.. no codes...
Power supply is there... 110 and 12V on both sides the fuses.
Jumped the electric heater and it will keep stuff froze in the fridge..
(Plug saved from the last dealings with this POS)
Noticed that the interior light will come on just for a second when restarted, or flicker with tapping the control board...
This fridge was REPLACED once... and had issues with the replacement...
and here we are again....
TIA from a very Ticked and disappointed FR Customer.
Retired Paramedic
2020 FSX 280RT
2005 Silverado 1500 Ext cab 5.3 H.O.
2011 HD Road King
Nights camped since 2019.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
09-01-2020, 08:12 PM
Just as confused as you
Sounds like a problem with the control board. Don't blame FR for the problems with your Dometic fridge. FR only installs the fridge built by Dometic, so it's a problem with Dometic's product. Contact Dometic's customer service.
Richard & Jill
09-02-2020, 10:00 AM
If tapping on the control board causes the light to flicker then you have a broken trace or loose/corroded connector on the board. You can pull it and try to find where it's at or you can buy a new board and replace it and that should fix your problem.
I'd try repairing or replacing the board before I'd replace the fridge again.
One thing you can try is to pull and clean every plug in connector on the board and see if that fixes the issue.
Gotta go campin!
09-02-2020, 12:02 PM
Connections have all been checked. no shorts found anywhere...
Guessing I'll hunt a control board.
Retired Paramedic
2020 FSX 280RT
2011 HD Road King
09-02-2020, 01:55 PM
Dometic Refrigerator in Isata 3
I just had a similar problem with the Dometic Refrigerator in our 2020 Isata 3. It quit cooling - No Codes just not cooling. AND I could not find a Dometic dealer who would do warranty repairs. I went online and, after much searching found the Dometic Refrigerator Training Manual:
https://myrvworks.com/wp-content/upl...r-Training.pdf
After checking all of the fuses I disconnected the P-2 THERMISTER HARNESS from the Integrated Control Circuit Board (Manual p. 65) to bypass the thermister and test the Cooling System system. Left it alone for 6 hours and everything got cold again. Reran same test in AUTO and LP modes with same results. After an overnight rest I replugged the P-2 Thermister harness into the board and tried the fridge again. IT NOW WORKS! Don't ask me why or how this fixed the fridge - I don't have a clue. Maybe the long disconnect time reset something, maybe an air bubble in the cooling line disolved. What ever, I just know that the fridge is working again. And it only took me the better part of 5 days trying each test.
I hope that this helps resolve your lack of cold. Good Luck!
09-02-2020, 02:48 PM
I also am experiencing refrigerator problems with a DM2872RBX. Dometic customer service center has temporarily ceased operation, per my dealer. They are projected to reopen end of October! They do not respond to e-mails, etc. and though they committed to replacing/shipping a new refrigerator, closed prior to shipping the item. Three weeks past, I waited 2.5 hours to speak to their Elkhart customer service. I was caller #10 in-line and waiting! Post if you have any success in contacting them.
09-02-2020, 03:50 PM
Thank you for passing on the link to the Dometic Refrigerator Training Manual:
Tim
09-04-2020, 03:11 PM
Originally Posted by TimVWulp
X2. Very useful manual.
Fred W
2019 Flagstaff T21TBHW A-frame
09-04-2020, 04:08 PM
If you can't figure it out with this.... hire someone.
2017 Puma 297RLSS
09-04-2020, 05:16 PM
Service & Training manuals have been in the Library section of this forum for quite some time. Click on Library next to User CP on the light green bar, you may be surprised what you can find there.
Library : https://www.forestriverforums.com/forums/downloads.php
Appliance section : https://www.forestriverforums.com/fo...hp?do=cat&id=1
Richard & Jill
09-16-2020, 08:31 AM
SCAPPER
Thanks for the reply.... I hold FR responsible for a lot. This POS has been nothing but issue after issue... Fridge, AC, thermostat, stereo, plumbing leaks, Awning,roof issues.... interior walls buckling.... honestly the water heater and outside fridge are the only things we've not had issues with... YET
Retired Paramedic
2020 FSX 280RT
2011 HD Road King
09-16-2020, 08:49 AM
After checking all of the fuses..........
IT NOW WORKS! Don't ask me why or how this fixed the fridge - I!
Had that issue the last go around... couldn't any get help.
made a jumper to plug in the 120 heater to use for that trip... then it just started working again... now a year later SOS....
New control board.... and it still doesn't work...
Fridge light now stays on BUT a few seconds later all 3 panel lights flash
Code E0.... Means REPLACE THE CONTROL BOARD... WTF...
Retired Paramedic
2020 FSX 280RT
2011 HD Road King
09-16-2020, 08:52 AM
Thats why I love the Forum.... been way more help than FR or the sub manufactures...
Retired Paramedic
2020 FSX 280RT
2011 HD Road King
09-16-2020, 09:01 AM
replace the control board with a dinosaur brand control board. OEM board have a bad track record.
You may have a bad converter that is delivering more than 14.4 volts when you plug in to 110 volt power. this will cause electric boards to fail also,
09-16-2020, 09:17 AM
You may have a bad converter that is delivering more than 14.4 volts when you plug in to 110 volt power. this will cause electric boards to fall also,
Bad converter.... Why not.... actually haven't had issues with that either...
Thanks.
Retired Paramedic
2020 FSX 280RT
2011 HD Road King
09-22-2020, 11:32 AM
Thanks.
13.4 volts from the AC Converter.... so thats not it....
This POS is for sale
Retired Paramedic
2020 FSX 280RT
2011 HD Road King
