Old 10-24-2017, 11:11 AM   #1
Fushux's Avatar
Dometic DMR702 Not Working on AC
I’ve got a Flagstaff 5th wheel that will not run off AC. It’ll just run on propane. The trailer is plugged in to shore power at my house. Where do I start? Not much of a problem this weekend cause we will be dry camping but I’d like to get it resolved.
Andrew
Fushux is offline   Reply With Quote
Old 10-24-2017, 11:14 AM   #2
jeff64's Avatar
Have you pulled off the vent/grille on the outside of the coach and verified that it hadn't come unplugged from the outlet that's inside there?
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 10-24-2017, 01:17 PM   #3
Fushux's Avatar
Yup. All looks good.
Andrew
Old 10-24-2017, 03:23 PM   #4
Do you have 120 volts to the receptacle it's plugged into?
If so do you have 120 volts between P3 & P4 on the board?
Have you resistance tested the element to see if it's good?
Gotta go campin!
Old 10-24-2017, 05:32 PM   #5
Fushux's Avatar
There does not appear to be 120 volts to the receptacle.
Old 10-24-2017, 05:53 PM   #6
Flybob's Avatar
Check the circuit breaker for the fridge.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-25-2017, 09:47 AM   #7
As FlyBob said check the breaker, then check for a tripped GFCI receptacle. The receptacle with the GFCI could be anywhere.
Gotta go campin!
Old 10-25-2017, 10:10 AM   #8
Thurman's Avatar
I also had a problem with the fridge, microwave, and all 110vAC outlets not working, just one time. I found that a GFCI outlet in the bath had tripped and that ALL of the 110vAC in the rest of the TT was supplied from this one outlet. I reset the GFCI and all had been good since.
Thurman is offline   Reply With Quote
Old 10-25-2017, 02:26 PM   #9
Fushux's Avatar
Checked GFCI (in bathroom) and was not tripped. Double checked the breaker and all was good. We’re dry camping this weekend so the fridge will be fine running on LP. I made an appointment to take it in on Tuesday. Fridge is currently cooling with an extension cord and I’ll switch to LP when we leave on Friday.
Andrew
Old 10-25-2017, 03:17 PM   #10
You may have more than one GFCI. Our previous unit had one in the bathroom and one under the awning outside.
Gotta go campin!
Old 10-25-2017, 11:36 PM   #11
Tom48's Avatar
Be sure to reset breakers full off, then flipped on. See where else is without 120 v AC. Breakers might be marked, and marked wrong
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS
NO MORE Tricked out
2017 Sandstorm 250 T.H.
Tom48 is offline   Reply With Quote
dometic
