The DMR-702 handle kind of snaps into place. The screws are backup and keep it from sliding up or down IIRC. When mine broke, some thin screwdriver prying in the right place got it off.
My problem was identifying the correct replacement. My DMR-702 was from 2014 and the handle design changed sometime after that. I found a couple of handle part numbers that were pretty vague at identifying the handle I needed and what was meant by left or right (hinge side or door handle side?). I ended up with a newer handle that did not match the freezer handle, but did work.
