Old 08-10-2024, 08:57 PM   #1
Dometic Duo Therm AC - Only Downdraft, No Vents
Both of my Dometic DuoTherm AC units blow the cold air directly down from the unit instead of into the ceiling ducts. Is there a way to change this? I've tried sliding the door to close off the air from the unit, but nothing comes out of any vents. Both my air units are acting this way.
Disclaimer: This RV is new to me (2008 Georgetown)
08GeorgetownBunkie is offline   Reply With Quote
Old 08-10-2024, 09:17 PM   #2
bikendan's Avatar
Originally Posted by 08GeorgetownBunkie View Post
Both of my Dometic DuoTherm AC units blow the cold air directly down from the unit instead of into the ceiling ducts. Is there a way to change this? I've tried sliding the door to close off the air from the unit, but nothing comes out of any vents. Both my air units are acting this way. You can see the tab in the middle. Push it to the right to close
Is this your first RV with ducted air?
Close the lower vent and it will route the cool air to the ceiling ducts.
It's called a dump vent and it's open.
Old 08-10-2024, 09:28 PM   #3
"...I've tried sliding the door to close off the air from the unit, but nothing comes out of any vents. Both my air units are acting this way...."
Old 08-12-2024, 11:04 AM   #4
RVwino's Avatar
Remove the AC’s filter grate. You should see visible openings for the channels which lead to the ceiling vents. Possibly, the previous owner did something to block them?
Cliff Smith
Jackson, CA
2021 FR3 34DS (V8)
2011 Honda CRV toad
RVwino is online now   Reply With Quote
dometic, vent
