Old 01-26-2024, 08:35 PM   #1
Dometic fridge not cooling
So I got a 2021 trailer, with a Dometic DM2872RBX fridge. All has been great, but we were out at our seasonal site last weekend. Temps were about -20f over night, but we were nice and toasty inside. Things seemed fine until Sunday we went to make lunch and noticed the burgers in the freezer were soft. Oh great. Look at the fridge outside, and there was a giant icicle hanging off the drain tube. Turns out snow melting on the roof was dripping right onto it, causing a 2 foot icicle. Also causing some spashback that may have gotten inside the cover. I wasn't able to open it at the time to see due to the ice.
Fridge seems to have power fine. If I kick it to gas, it fires up and I can hear the flame. Just doesn't seem to be getting cold. The 120v plug has power as well.
Any thoughts? Tips? What to try?
Offspring22 is offline   Reply With Quote
Old 01-27-2024, 10:56 AM   #2
To add a bit more, left it on over night on gas. It's sitting at about 60f, so maybe a little cool, but not "cold". The boiler was a bit warm. Not hot by any means.
Old 01-27-2024, 07:39 PM   #3
Is the roof vent clear of ice?
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 01-27-2024, 07:44 PM   #4
As far as I can tell. No/snow/ice for a good 6" around it, and it's quite warm to the touch.
Old 01-27-2024, 08:00 PM   #5
I did see in another post that they turned theirs off for a while then turned it back on and seemed to be cooling at that point. Try that and leave it on gas.
Dale & Karen
Old 01-27-2024, 08:03 PM   #6
It was off for 5 days, and no better when fired back up unfortunately.
Old 01-27-2024, 08:09 PM   #7
Well, sorry I was no use, maybe someone else will jump in with some ideas.
Good luck.
Dale & Karen
Old 01-27-2024, 08:10 PM   #8
Appreciate it anyway, thanks!
Old 01-27-2024, 08:14 PM   #9
Well, the good news is that if it's -20℉ outside, the whole world is your freezer.
The bad news might be the way absorption refrigerators work. They use heat to boil the refrigerant and compress the steam. They let the steam blow through an orifice where it expands. Expanding gases cool in a coil (like Right Guard under your arm) and air moving over the coil cools the contents.
That part of the refrigerator is on the outside wall, behind the plastic cover. It is possible that at -20℉, the refrigerant simply isn't getting hot enough to do its job--even if it does feel hot enough to melt snow around the vent.
Larry
Larry-NC is offline   Reply With Quote
cooling, dometic, fridge
