Old 11-06-2019, 01:46 PM   #1
Dometic Fridge not working on electric but propane works.
I have a 2016 dometic refrigerator in my Flagstaff MicroLite. It suddenly quit working when hooked up to electric but the propane setting works fine. I have had it looked at by a service tech who said it was fine. After another short trip it was not working. I have had all the connections and fuses metered and all are in working order. I have a feeling it is the circuit board behind the black plastic cover that is the problem. Does anyone have any other ideas? I am about ready to order that board online and hook it up myself.
WintrTexn19 is offline   Reply With Quote
Old 11-06-2019, 01:55 PM   #2
Head Rambler
Does the electric element test good? Do you know what the Ω (ohm) reading is?
Have you checked the thermofuse? It looks like a small metal fuse or diode with leads out each end.
You say you had the connections metered, but were they pull tested for tightness?
Gotta go campin!
dometic, electric, fridge, propane
