Old 05-26-2016, 05:11 PM   #1
Drivestregis
Drivestregis's Avatar
Dometic fridge runs only on propane
2014 Solera S. Dometic fridge runs well on propane. Will not run on electricity. Any ideas on trouble shooting and fixing?
Drivestregis is offline   Reply With Quote
Old 05-26-2016, 05:16 PM   #2
Who Dares, Wins
doc73's Avatar
Check the breaker
Sent from my SM-G930V using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 05-26-2016, 05:38 PM   #3
Does the element get hot?
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 05-26-2016, 06:12 PM   #4
Drivestregis
I checked the breaker by the door and nothing was tripped. I also checked the fuses in the panel available when you remove the exterior vented panel
Is there another breaker area?
Drivestregis
2014 SOLERA S
Retired Cajun
2015 Honda Fit Toad
Old 05-26-2016, 06:13 PM   #5
Drivestregis
The element gets hot when the fridge is running on propane but not on electricity.
Drivestregis
2014 SOLERA S
Retired Cajun
2015 Honda Fit Toad
Old 05-26-2016, 06:17 PM   #6
DaveSchwartz's Avatar
On my TT, the AC cord for the fridge was plugged into a receptacle that you could see when you took off the lower outside grill. And since it was accessible from the outside, it was run from a GFCI. Check that the receptacle isn't itself a GFCI, or daisy-chained from a GFCI, that needs to be reset.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 05-26-2016, 07:09 PM   #7
Take the frig panel off the outside of your camper and make sure its plugged in. I just had this same problem with mine a few hours ago. The lights on the frig still worked because they run off of 12v.
2016 Coachmen Apex 288BHS
2015 F150 Sport 4x4 3.5 Eco Boost
4B11T is offline   Reply With Quote
Old 05-27-2016, 11:28 AM   #8
Ham Radio since 1970
N9ID's Avatar
X2
Mike & Nena Strong
2013 Cedar Creek 36RE
2012 Chevy Silverado Crew Cab 3500HD Diesel 4WD
Nights camped '14: 51 '15: 134 '16: 149 '17: 171
N9ID is offline   Reply With Quote
Old 05-27-2016, 12:01 PM   #9
Drivestregis
Still will not work
It is plug into the receptical. I could find no GFI near plug and wires disappear into a wall. I did check the GFI by the bathroom sink and it had tripped. I reset it. Fridge still did not come on when I turned it on.
Any other ideas?
Old 05-27-2016, 12:06 PM   #10
prof_fate's Avatar
take off outside grille and see if there is power to the fridge outlet (tester or plug in a fan or light).
If there is power to the outlet and fridge won't run...it's the fridge or heater element or a broken wire.
For 2 years now i've the opposite problem- the fridge won't start on propane. IF i can get the pilot lit and stays lit i'm good - it will cycle -usually. Like going down the road. I've changed the ignitor...think my issue is the control module.
I had ZERO luck finding troubleshooting assistance on line (charts, manuals, test procedures, etc).
Good luck.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 05-27-2016, 12:23 PM   #11
Drivestregis
Thanks guys. Apparently the fridge GFI is the receptacle by the bathroom faucet. The coils are heating up and the freezer and fridge are starting to .cool.
Moral of the story for Solera owners: if fridge does not come on, check GFI next to bathroom sink
Drivestregis
2014 SOLERA S
Retired Cajun
2015 Honda Fit Toad
Old 05-27-2016, 01:53 PM   #12
if you are completely sure you have A?C voltage at the refrigerator outlet. Then turn of the power to that plug at the breaker, remove the cover on the circuit board ( Black box on back of refrig.) and check the two fuses on the board. You may have gotten a surge of power to blow one of the fuses.
hillsdaletc is offline   Reply With Quote
Old 05-27-2016, 02:32 PM   #13
Drivestregis
Hillsdaletc, check post number 4. First thing I checked was those two fusea. Thanks for trying to help. It was a tripped GFI.
Drivestregis
2014 SOLERA S
Retired Cajun
2015 Honda Fit Toad
Old 05-27-2016, 03:21 PM   #14
nuisance's Avatar
when mine went out the light on the front blinked 3 times pause 3 more blinks. The heating element had burned out for the electrical plus the "bakelite" around the reset switch broke.
[COLOR="Red"]Al and Deb
Sugar and Anna Belle
2016 Toyota Tundra
2011 Greywolf 26rl
nuisance is offline   Reply With Quote
Old 05-27-2016, 03:36 PM   #15
Mr. Dan's Avatar
Thanks for posting how you solved your problem. That helps all of us who read SUCCESS posts.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 80; booked = 14
Old 05-27-2016, 04:21 PM   #16
You're welcome.
Old 05-27-2016, 04:22 PM   #17
Pain in the rear but ohm test the heating element. Good video on you tube. That fixed my problem
Google element. Cheaper on line. Not hard to replace
pdqparalegal1 is offline   Reply With Quote
Old 05-27-2016, 06:18 PM   #18
Mr. Dan's Avatar
Read a couple of posts above where the problem and solution have already been posted.
Old 05-27-2016, 06:49 PM   #19
RSchleder's Avatar
I second this "thanks". Makes us feel like we helped you solve a problem and it was, indeed appreciated.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 05-27-2016, 11:21 PM   #20
MNtraveler's Avatar
Agreed - was checking this plug socket today and didn't know it was GFCI controlled. Learned something new.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
dometic, fridge, propane
