Old 01-09-2013, 07:27 PM   #21
TURBS's Avatar
Yw
Old 01-09-2013, 07:38 PM   #22
"Don't Tread on Me"
sgtsdj's Avatar
What did you mount the two externals on? What did you wire them to?
Steve J.
Retired VA Law Enforcement
, Good Sams Life Member
Rockwood Roo 235S
2002 F-250 7.3 Diesel Powerstroke Powerhouse
Chipped, Bank's Exhaus
t - "Bad to the Bone"
sgtsdj is offline   Reply With Quote
Old 01-09-2013, 07:50 PM   #23
TURBS's Avatar
The two externals were mounted to a filler plate that was removable.
I just cut two holes in it and screwed the fans to it.
Power came from the lower left of exterior fridge there's a cover there and a switched hot .
When u turn fridge on that junction is hot.
When fridge is off its cold.
I'll take pictures within the hour for you.
Turbs
Old 01-09-2013, 08:07 PM   #24
"Don't Tread on Me"
sgtsdj's Avatar
Wow. Thanks so much. I'll have to get you a "Get out of Jail Free card"
Steve J.
Rockwood Roo 235S
Old 01-09-2013, 08:20 PM   #25
TURBS's Avatar
First pic is of cover.
One screw at top and two little dinky push tabs on bottom right and left.
Second pic is curcuit board lower left hand side is switched power.
Thirds is the grounds
Picture of filler panel with fan.
Hope this helps
In first pic that black cover has writing at the bottom telling what all the circuits are.
Notice three fuses!
Turbs
Old 02-23-2013, 01:51 AM   #26
speters53's Avatar
How did you wire the fans? Looking at the third picture, it looks like two wires(red & yellow) go into one red. Saw the circuit panel pic, but still don't understand the wiring. Not an electrical wizard, so any help would be great. Thanks.
2012 Sandstorm 34ft 5th Wheel Toy Hauler 3215
2012 Chevy Silverado 2500HD Duramax Crew Cab 4X4 Long Bed
speters53 is offline   Reply With Quote
Old 02-23-2013, 02:21 AM   #27
SYE
SYE's Avatar
Turbs
Is your fridge in a slide, mine is and there is no access panel like you have, just a vent toward the top of the slide so I am wondering where I would put the ones on the outside.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline   Reply With Quote
fan
