Dometic reads 32 degrees fahrenheit
Our Dometic keeps reading 32° Fahrenheit so it will stop cooling. After a quick google search this seems to be a common problem. Two suggestions to fix it are pull the cover and check the wires for being loose or condensation. The other is check the remote sensor for condensation and or unplug it and just use the Sensor in the dometic itself.
Does anyone know where FR usually puts the remote sensor and what does it look like?
Or is there a post about how to unplug it?
I am pretty sure I can get the cover off and check the wires I just have no idea where the remote sensor is or what it would even look like. Unless it looks like a typical sensor you see in refrigerators and such.
