Originally Posted by Powerstroke_dude
Hi guys, so when I’m running propane my refer will not cool down at all. If I run power shore or genny it stays cold. Freezer stays cold either way. Any ideas or suggestions?
Without knowing the make and model of your fridge, we can only give an idea why the fridge section is not cooling.
Open the door to the fridge, looking at the cooling fins on the upper back there should be a plastic clip on the right hand fin. Sometimes this clip can fall off the fin. Other times this clip has a tendency to slide down when traveling down the road.
Moving this clip up towards the top of the fin will lower the temperature in the fridge section.
