Old 08-01-2021, 02:48 PM   #1
Dometic Refrig FYI
I have a Dometic refriq in our Rockwood 2506S mini lite.. I also have a buddy with a Dometic refriq and his refriq drain "hose" that suppose to go out of the refriq access cover door outside was not positioned correctly and was draining the water from the drip tray "inside" the compartment and running down inside the exterior wall just below the access cover and destroyed the wall.
Check you drain hose and make sure it is draining propering "outside" the cover to prevent your exterior wall from water damage..
It is easy to misposition this hose if you remove the access cover.. FYI
Clint...
2015 F350 4x4 gasser.. 2017 Rockwood 2506S TT
Ardenvoir, Washington (near Wenatchee)
clintbonnie73 is offline   Reply With Quote
Old 08-02-2021, 07:38 AM   #2
SeaDog's Avatar
that is a good reminder I'm going to check mine today when I pick it up from the ranch.
Retired Navy
2016 Flagstaff 26 FKWS
dometic
