Backside of RM1350 Door Liner
Everything looks to be bonded together, I don't have the RV here but part of the reason it broke is that the foam insulation did not flow into the ear of the liner so it was just hollow plastic instead of foam filled plastic.
Bottom line is that you can't get to the backside to reinforce the glue joint.
I reached out to Dometic so we will see what they have to say and maybe the acrylic two part plastic bonder works just fine. Maybe Dometic had a problem with the doors and I will get a new door? Never hurts to ask.
Steve
2023 Jayco 195RB
