Old 10-31-2020, 08:30 PM   #1
Dometic RM1350
Display flashed E0 then went blank. Any help is appreciated. I am not able to lift anything that heavy. How hard is it to work on. Is there a fuse somewhere that I could check out. Dealers are no help and repair shops are to costly.
Caddisfly49 is offline   Reply With Quote
Old 11-01-2020, 09:40 AM   #2
Gwiggels's Avatar
E0 is a diagnostic code that states there is no communication between the display and the power module. There is a 5amp 12v mini fuse and a 5amp 120v glass fuse that can be checked. The power module is located on the backside of the refrigerator. The lower fridge vent access panel will need to be removed. Dont forget to disconnect 12v and 120v power from the refrigerator. I have attached a few pictures that might be of some help. Click image for larger version
ID:	242307Click image for larger version
ID:	242308Click image for larger version
Gwiggels is online now   Reply With Quote
Old 11-19-2020, 10:08 PM   #3
The 120 volt 5.amp fuse fixed my problem. Thanks for the help.
Old 11-20-2020, 08:55 AM   #4
Head Rambler
Thanks for coming back and letting us know what you found and that just replacing a fuse fixed it. I'm glad it was a simple fix, and you didn't have to employ a service call to figure it out.
Gotta go campin!
Old 11-20-2020, 08:59 AM   #5
Gwiggels's Avatar
Glad to hear it was an easy fix
dometic
