Old 05-16-2022, 07:34 AM   #1
Dometic RM1350 refrigerator not cooling
Please help if possible
Left home two days ago fridge worked great, next day it appears to be running on electric and gas I can hear both. Sounds normal but no cooling. I turned off the unit and tried a restart. Still the same. I hit the reset on the back of the unit. It was tripped. But still all the same. Looks and sounds normal but no cooling. Sitting at 60* frustrating to say the least. Turning a good trip into a bad one.
Thank you
mouerlabs is offline   Reply With Quote
Old 05-16-2022, 07:44 AM   #2
bubbles's Avatar
I don't know if it would power up if blown but there are 2 replaceable fuses on the circuit board accessible from the back.
Old 05-16-2022, 07:54 AM   #3
bubbles's Avatar
The manual is no help it says to shut it down and call Dometic if it stops cooling. It also says to not keep restarting unit.
Old 05-30-2022, 09:35 AM   #4
Checked both fuses and both are good 🤷🏼*♂️
Old 05-30-2022, 09:55 AM   #5
Mr. Dan's Avatar
A refrigerator doesn’t run on both power sources simultaneously as a water heater can.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 68; Booked for 2022 = 41
Old 05-30-2022, 09:57 AM   #6
You are correct. It cycles back and forth. But not at the same time. You can here when the electric comes and then shuts off and then the propane fires. But nothing cools.
Old 05-30-2022, 10:07 AM   #7
Mr. Dan's Avatar
Thereís something wrong if it cycles between the two sources. IF the control panel switch is set to Auto, the fridge will operate on electricity if present and on propane if no electricity is present. If yours with cycling between the two, your electricity may be going off/coming on.
I have new hearing aids and I donít think I can hear mine operating on electricity except for heat-induced ticking.
Old 05-30-2022, 10:10 AM   #8
Mr. Dan's Avatar
How does this current issue relate to the problem you posted here? https://www.forestriverforums.com/fo...de-250922.html
Old 05-30-2022, 10:22 AM   #9
What is the year, make and model of your rig?
You've done the recommended fixes, so you may need to contact Dometic or your dealer.
In the meantime, a bag of ice might help salvage your weekend. Just treat the refrigerator as a huge cooler.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 05-30-2022, 07:34 PM   #10
I wish it were that simple. Steady electricity
Old 05-30-2022, 07:35 PM   #11
Yeah I went to Lowe’s and bought a residential fridge to get me through.
Old 05-30-2022, 07:38 PM   #12
Well the fridge wasn’t working at all then it started cycling on and off ����*♂️ I have a new circuit board coming in a few days. Hoping that’ll fix it.
Old 05-30-2022, 08:40 PM   #13
bubbles's Avatar
We are assuming you did select AUTO/GAS for LP mode, to check that side correct?
Old 05-30-2022, 09:10 PM   #14
Yes you are correct
Old 05-30-2022, 09:26 PM   #15
Ok possible problem. I have no power to any outlets. The two GFIís have a yellow light. It will not reset. Great.
Thank you
cooling, dometic, refrigerator
« Who Knows? | Fridge »
