Originally Posted by Slinks
Had some repair on my 1350 and noblongwr able to make ice. Any suggestions?
Sure, there's a water supply pop it valve outside fridge compartment furnishes water to IC maker and drinking water, trick is the control solenoid for the ice maker and mechanism is run by 117 VAC, whereas the water on the door is a 12VDC supply. Believe you must have all three water, and two power supplies to make ice. BTW the AC is supplied via a household plug also located in the outside reefer compartment . Maybe this will help for starters.
