Dometic RM2852 Refrigerator will not come on
I have 118 volts coming out of the plug and going to the circuit board. Both fuses are good as they ohm out to 3 and 5.
I have 12 volts at the block where white wire and white with yellow stripe wire come out. This one has an inline 5amp fuse and it is good.
No power at the switch on the top left above the freezer door.
No lights on the control panel, inside light does not come on.
Any help would be greatly appreciated
