We own and 2020 No Boundaries 16.2 trailer which we bought from Camping World new. When you turn on the heater the air conditiner turns on a minute or so later. Camping World has been unable to diagnose the issue but has tried replacing the the Dometic thermostat which did not work. I have emailed Dometic but they failed to respond. Any suggestions?
Thanks, Chris
is the fan on your thermostat set to auto? if on hi or low, i believe the ac fan turns on as well as the furnace... at least i think thats how mine works...LOL been a few months since i needed the furnace...
2017 Primetime Crusader Lite 27RK
2008 Ford F350 King Ranch 6.4l
If the fan is set to Hi/Lo, it (the fan) should run continuously. The AC compressor shouldn’t kick on if the furnace is running.
