05-11-2016, 02:29 PM
Electrical outlets not working
We have a 2014 Coachman Liberty Express. Two outlets above the sink and one just below the sink are not working. Checked fuses and they are good. All the other outlets work. Any suggestions on how to fix this. Thanks
05-11-2016, 02:34 PM
Besides obviously checking circuit breakers, Check that the GFCI on one of the nearby outlets are reset. (ask me how I know! )
05-11-2016, 04:27 PM
X2 press reset button.....
Fonzie
05-11-2016, 04:39 PM
Thank you. The only GFCI we found was in the bathroom. It works. Just the three outlets in the kitchen are not working. Any other suggestions?
05-11-2016, 05:02 PM
Usually there is two outlet that are GFI's, one in the washroom and one either in the kitchen or outside.......
Fonzie
05-11-2016, 05:18 PM
How many breakers do you have for outlets. My windjammer has only one. The reason I ask this question is that if you have two breakers then you might have two GFI's. If you only have one outlet then you have a loose or missing wire at one of the outlets in the run.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
05-11-2016, 05:25 PM
You don't say what model Freedom Express. If you have an outside kitchen, you might have a GFI in it. Also check the outside outlet.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
05-11-2016, 05:53 PM
Thank you all very much. We will check the outside outlet. Not with camper right now. It is at the campground but going there tonight. You have probably solved our problem.
05-12-2016, 12:47 PM
Our GFCI is on the outlet under the dining table seat. Rarely used outlet, so it was a surprise to see it there.
Joe & Sue - Camp Mutt Duke
2008 Flagstaff Super Lite 26RKS
2008 Ford F-150
05-12-2016, 03:08 PM
We had a similar issue with our 323MK Wildcat this year but at my house. Plugged my 50 amp trailer into a 110 house outlet (after downsizing to 30amp then 15 amp adapters). No outlets would work. Took it into our dealer and discovered my hardwired EMS wouldn't allow the trailer outlets to work. It was doing its job. Told to just turn off the EMS because the low amperage house outlets wouldn't harm the electronics in the trailer. Did it and now the outlets work fine at my house. If you have a surge protector check it out. It may be protecting your trailer.
05-12-2016, 03:38 PM
Originally Posted by rogerkathy
Told to just turn off the EMS because the low amperage house outlets wouldn't harm the electronics in the trailer. .
I would be very careful taking any suggestions from the person who told you this as it it wrong. GFI's and EMS units sometimes don't play well together when connecting RV's to garage outlets
TST Tire Monitors
2 100W solar panels
05-12-2016, 04:20 PM
X2...
Fonzie
05-12-2016, 04:41 PM
I had same problem but gfci wouldn't reset after it tripped while DW was trying to use a blow dryer. 2 downstream outlets would'nt work. Turned out to be a bad gfci outlet. Replaced and all worked well after that. There was an outlet in the cargo bay that was hard to find that wasn't working and one one the island.
2013 Ford F250 6.7L lariat
2016 Wildcat 275 CKX
50 Gallon Titan tank
Firestone Ride Rite airbags
Airlift Wireless compressor
05-14-2016, 04:37 PM
Is there a way to check the GFI outlets besides the reset button?
02-22-2017, 11:56 PM
This may be an old thread, but the info. found here was very helpful to this newby! I check GFCIs in my house but hadn't thought of it for our trailer. Problem solved!
