Originally Posted by CustomBuild
Recently my refrigerator started to show signs of a problem with cooling and I noticed the blue power light was flashing. I checked the forum and found a number of posts although none of them seemed to solve my problem, so I thought I would post this message in case it helps anyone.
The bottom line is my unit was covered in ice behind the back panel of the freezer section. I emptied the refrigerator, removed the back panel, left it to thaw out for one day and then started it up again. I guess I could have just left it to thaw without removing the panel although that was how I actually discovered the problem.
Anyway, one it was thawed I fastened the panel in again, turned it on and it works perfectly once more. So no issues with voltage, no issues relating to the damper, just a simple case of frozen solid inside.
What temperature setting (refrig LED setting) did you have it set to? Where do you have the setting in the Freezer set to?
My Everchill has be running 24/7 since April/May of 2021 when I bought my Vibe and it has never stopped cooling or froze up (coils). When I'm traveling the refrig is set to #3 (when not traveling and camper is parked at home with very little in refrigerator its set to #2) the Freezer setting is
Always at about One o'clock. Once a year I shut the refrig off (pull fuse) and pull the back freeze panel off, but I have
never had any ice back there. I Live in NE Florida.
So the question is, why are you getting an ice build up on the coils??? My thoughts would be your temp settings, especially the Freezer knob that adjust the amount of cold air that goes to the refrig box from the Freezer area. Or you have an air leak around the freezer (and/or) refrig door allowing (humid) room temp air to get in the freezer. There was a thread
HERE that discussed a freezer door air leak.
Perhaps if you have an infrared temperature gun you can check around the doors/seals to look for cold air leaks spots.
I'm glad you found your issue and got your Everchill back working. But, my experience has not been seeing any ice buildup on the coils in the Freezer that affects the units operation.
-Russ
