Everchill Fridge Not Cooling
We have a 2020 Puma 28BHSS with an Everchill fridge. I pulled it out of storage this week and have discovered the fridge is not cooling. We’ve not had this problem before. The fan runs in the freezer, but the compressor will not kick on. Fuse and breaker check out fine. I’ve powered everything down and let it sit for a couple hours in hopes that it would reset, but no luck.
Any other tricks I can try or tests I can run on the control board etc..
Thank you for your help!
