Thanks for changing the post title (had Fleetwood, our old RV).
The fridge is a Dometic 2852RBX
I’ve looked through the manuals. A few questions I don’t see answers to:
1 - Any description or diagrams for the thermal probe inside the fridge. Assuming the probe tip is supposed to be inside the clip? (See attached image)
2. The drip tray under cooling fins. No idea where that water goes. It is lined up so the water goes into the little port but that goes “somewhere”.
I’ve removed the back bunk top to look and no water there. I removed the front panel for the furnace (under the oven), no water. I also removed the power panel and see nothing there and it is located directly under the fridge.
The water is coming out under the tip of the small wall panel (attached image)
