Assuming (yes, I know) it’s a basic Maxxair fan start by removing the screen by turning each of the 4 clips that hold it 180 degrees. You can now remove the screen.
Next, remove the knob by removing the screw in the center of it.
Next, remove the 4 screws holding the fan body in.
You should now be able to lower the fan body and inspect the power cord. This is a two prong plug that carries 12 volts and ground. Check that it’s plugged in tightly and that the wires are crimped in securely.
If still not working disconnect the 2 pin plug and check for voltage on the camper side of the plug.
If you have voltage to the fan and all the wires and plug connections check out you may have a bad fan.
2021 Rockwood Mini Lite 2205S
2011 Ford F-250 Super Duty 6.7L Diesel
