Old 10-07-2024, 02:45 PM   #1
FR 2004 Sunseeker Microwave
New to this Forum. Good ,what ever the time of day it is in your neck of the woods. I am seeking information on the Sunseeker Magic Chef microwave. It lights up and you can put a time, Or press a setting but when you press the start button nothing happens. So I am looking for a replace it. Does anyone have an Idea on the best Microwave replacement. Thank you in advance.
HowlinWolff is offline   Reply With Quote
Old 10-07-2024, 03:07 PM   #2
Oaklevel's Avatar
Welcome to the forum from Virginia !!!!
As far as the microware, I would just find a microware that as close as possible fit in the hole.
As far as the old one I would check for possible blown fuse in the microwave itself.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Lillie Boxer Mix (RIP)
Old 10-07-2024, 03:10 PM   #3
bikendan's Avatar
Moved thread from the Welcome Mat section to the Appliances and Electronics sub-forum since the OP's post is strictly about an appliance and not an introduction post.
Old 10-07-2024, 05:58 PM   #4
2006 Sunseeker 2860DS. 5 or 6 years ago our microwave blew when an electrician miswired our 30 amp pedestal at home.
Any microwave the same size will work or that's what I was told when I asked. Look at Walmart, big box home improvement centers. Our rv dealer replaced it at the electricians expense (the converter blew too and the electrician paid for that too)
Our oe microwave was a Magic Chef. New one is a Criterion I believe. I think it was way less than $100. Works great!
ChrisParise is offline   Reply With Quote
Old 10-08-2024, 01:03 PM   #5
There are many to choose from. Sadly, I've never seen an LG or GE.
Generally, fit and appearance are deciding factors. Note that RV micros come with the retaining plate that matches the micro. That's the primary difference between a counter-top micro and an RV micro. Look carefully at the retaining/trim plate. They are not all perfect matches in alignment with the factory model.
Illustration of choices.
Look on eTrailer, too.
Jim Moore
SW Colorado - 4-Corners Area
2020 Jayco X213 Rear Slide, 2006 RAM 1500 with Firestone Airbags No WDH
400 watts of solar on the roof & 200 watts of suitcase & 2 x GC2 batteries
Starlink Gen-3 running from a 500 watt pure sinewave inverter
Boondock almost exclusively on the shores of Lake Vallecito
jimmoore13 is offline   Reply With Quote
Old 10-10-2024, 02:09 PM   #6
Here is the Magic Chef replacement my rv dealer bought and installed for me.
Note, the manual says its a counter top model. I would remove yours and take the mounting bracket off and see if it fits whatever you're considering. It is not absolutely necessary to buy a built in which are 4 to 5 times the price.
Had the Criterion now for 5 years put thousands of miles on it during my travels.
Hope this helps.
ID:	304699   Click image for larger version
microwave, sunseeker
