Originally Posted by Mike Sedillo
Thank you so much for that reply. I thought that the amber light meant it wasn't on! But.....the refer is not getting cold with the amber light on. The pilot is lit, I can see the flame.
Your refer has no pilot flame. It ignites the gas by a spark. If you see flame it is operating normal. If the gas fails to ignite you will get a solid red light on. The only difference between running on electric or gas is how it heats the solution. If the thermistor was bad it would not cool on electric or gas.
Does the unit actually warm up inside when on gas after cooling down on electric or just never get cool when on gas? It does take hours before it will cool down on either. I usually put a bottle of water or something similar in the freezer and check if it is cold after a few hours. I hope this helps. Good luck.
Read on page 19 under Burner in the manual linked by Kenandterry.
