Old 09-26-2020, 01:31 PM   #1
Fridge door warning and thermostat location
Our Hisense residential fridge decided the freezer door is not shut. But it is. It shows the dr warning. I cannot figure out where the prox switch is that it uses to decide whether the door is open. Any ideas?
Also, we have 2 air conditioners and both the thermostats are in the same location by the pantry. What's up with that? And I don't like the thermostats. The left one is for the rear ac and heat. The right one is for the front ac. Can I replace these with better thermostats? Would love to move the front one into the bedroom but not sure how much trouble that would be.
Thanks,
Corn
ID:	240010   Click image for larger version
corn18 is offline   Reply With Quote
Old 09-27-2020, 08:08 AM   #2
SeaDog's Avatar
Can't help with the fridge door. Changing the stats is an easy task and well within most RVers ability. Moving the stat may be somewhat harder depending on the location you will have to fish wires down the wall.
Retired Navy
2016 Flagstaff 26 FKWS
cat, door, fridge, location, thermostat
