Old 05-14-2016, 10:12 PM   #1
RangeMaggotBob's Avatar
Fridge drain hose
I have a Dometic fridge in the slideout of my RV. I took the top back panel off to clean out the dust, and there is a plastic tube hanging there with a plug in it. Looks like a plug, anyway. In my old RV, there was a hose that I assume did the same thing, and it was routed through a hole in the cover so the hose hung out about 6". Should this hose be hanging outside also? Did they miss something when they installed the fridge? And what about that plug? I didn't look that close; maybe there's small holes in it to drain. I will be looking again on my days off, but any help will be very appreciated! Thanks!
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
And new to our family: Daisy May, the Golden Doodle wonderdog!
RangeMaggotBob is offline   Reply With Quote
Old 05-14-2016, 10:15 PM   #2
raspivey's Avatar
It has holes in it. Keeps the bugs out. It shouldn't have to stick out very far.
Old 05-14-2016, 10:32 PM   #3
Thank you! Should it be sticking out of the cover? Mine is just hanging loose inside.
Old 05-14-2016, 10:37 PM   #4
raspivey's Avatar
Mine just barely peeks out of the cover. Shouldn't really matter as long as the water goes where it's supposed to and isn't pooling inside the cover. It shouldn't like it is, but all you should have to do is poke it out the vent a little if it might be an issue.
Old 05-15-2016, 01:25 AM   #5
Pill Billy's Avatar
It should be sticking through a vent hole to drain outside.
Pill Billy is offline   Reply With Quote
Old 05-15-2016, 01:46 AM   #6
Yeah, I kinda thought so. It's not, and there's no sign of the water pooling; just got lucky, I guess. I will definitely re-route it outside. Thanks you guys, you've been a big help.
Old 05-15-2016, 05:16 AM   #7
fonzie's Avatar
Fonzie
Nights Camped:2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42) 2019(28)
Old 05-15-2016, 07:17 AM   #8
Restcure's Avatar
Originally Posted by fonzie View Post
In our previous trailer the hose split and broke. The dealer told me that the only way to fix it was to remove the fridge and the only thing they would use to replace it was the same fragile crack-prone plastic hose.
I did a lot of research and in the process came across the above video. The P-trap that she describes was not present in my original hose and did not work in the replacement; the catch cup in the fridge would NOT drain with a trap in it.
Furthermore, our fridge worked fine without a trap before and after the repair. I did it myself WITHOUT removing the fridge and WITHOUT using the same hose material.
A full write up is on our website at Repairs - Refrigerator Drain Line Replacement.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
Restcure is offline   Reply With Quote
Old 05-15-2016, 07:31 AM   #9
Good Info above! Youroo!!
Old 05-15-2016, 08:30 AM   #10
dcheatwood's Avatar
Yeah, let it stick out a hole in the cover and try to leave a bend in it so that it holds a little water like a vapor lock. Keeps outside heat out of the tube and bugs from crawling in.
2018 Forester 3011 DS
drain, fridge
